Old 09-12-2007, 02:35 PM   #1
ecks
Your Ride: 1996 318 is
==> Can't Get H2O Pump Out!!! <==
Thanks for all of the help so far. I know that I've saved so much already doing this myself. Last week when I started my car, I heard a squeak like a belt was loose, but everything was fine, or so I thought. A few hours later driving back on the fwy, my car started to really overheat like crazy so I pulled over.
Now I'm at home, fixing the problem. I got a thermostat and the housing because the 2 plastic clips that hold the thermostat in were missing. I also got a gasket for that. Well, when I looked down by the water pump I saw maybe 5 very small cylindrical barrings. I think those were from the water pump. Also, the part that comes out of the water pump that you attach the circle thing to that the belt rests on was really loose. Obviously I need a new water pump.
The problem is, I can't get the stupid water pump out! I removed all, 4 bolts and read the tutorial on pelicanparts.com that said to use a screwdriver and a mallet to tap it out. I mean, this thing is stuck. It almost feels like there are more bolts attached but I got them, all, the 3 regular ones and 1 long one. I really want to take a crowbar to it but I don't want to kill my car. I could really use some info on how to get this out. THANK YOU!!!
