Called BavAuto, Al said it was the oxygen sensor relay.
Apparently, the "Lambda" is the oxygen sensor and the "Lambda Control" is the oxygen sensor relay. He said that it could be that the O2 sensor isn't being told to warm up properly and that the cause of that could be the relay, as in code 1222.
Any suggestions on parts? Part numbers?
