Originally Posted by xsperf
distorted rotors(again, thats for you dudesky) . .
Thanks, but RSF5 went and said it anyway
"metal"- I think you should do away with the speculation and get under there . . only one way to find out for sure what the culprit is. I would guess either control arm bushings or tie rod ends. Bad wheel bearings will do that too, but that would be more pronounced through the brake pedal.
