Old 08-02-2007, 09:38 AM   #8
TechniqueTuning
Title: UB Supporting Vendor
Your Ride: 2001 BMW 330ci Turbo, 2002 X5 3.0
Originally Posted by xsperf
so a wastegate is like a boost controller? then do all turboed cars have blow off valves except some are louder than others?
A boost controller can be used in conjunction with a wastegate, to run MORE boost. No boost controller means you'll running whatever boost level the wastegate spring calls for. Installing a boost controller will allow you to run more boost than the wastegate spring (but not less).
A turbo car will either have a blow-off valve (whooosh sound) or a bypass valve (virtually silent whiskkkk).
Nick Glantzis
Technique Tuning Inc.
BMW Turbo Systems and Forced Induction Tuning
