did you get the 96-99 control arms?
did you get the 96-99 bushings as well?
if so did you get the 96-99 strut hats?
the reason i ask is that is just had the 96-99 m3 control arms and bushings installed and then came accross some material that says this setup will create too much caster unless the offset 96+ strut hats are used as well. apperently this will also create too much oversteer.
deloriant have you noticed any negative effects from this setup without the strut hats?
i am going to pick up my car from getting the allignment done right away here and am wondering whether i should be ordering the strut hats.
