you have more vac leaks if fixing one made it worse
I think I was too tired when I wrote this post. Once I fixed the vacume leak. ( pressure regulator to throttle body) the idle became worse. I have re-adjusted things to a place that is working but I still have 2 different idles. Low when cold and higher when hot...Backwards if you ask me.
I have been looking for other leaks and found nothing...
She is
very well but I know this can not be right about the idle.....
thanks
Jami
