Old 06-14-2007, 08:16 AM   #1
Davey D 67
Name: Davey D 67
Your Ride: 99 323i SE saloon
Unhappy vibration when braking
Hello all
I have a late 99 E46 323i (2.5) saloon and have got a problem which I cant seem to get fixed - therefore any constructive comments would be much appreciated...
Basically I had the front disks and pads changed all round in January 07 (not done by the dealer), everything seemed ok for the first 6 - 8 weeks, then I started to get vibration through the car when braking. The steering did not shake it seemed as though it was coming through the break pedal. I have since had the front disks and pads changed again and had the lower radius arm on the front passenger side replaced with the 2 ball joints and bearing (this was replaced only 13 months ago (both sides) and has had to be replaced yet again), the problem seems to have been aleviated a bit but I still do not have smooth braking - the vibration is a lot worse at higher speeds. I hav also had new tyres all round and all wheels balanced.
Could it be the rear disks are warped? can anybody suggest anything else. The car has not been heavily kerbed nor been in any accidents.
thanks for looking.
