Originally Posted by gdamato
. A clogged fuel filter makes sense. After the fuel lines have had a chance to drain back to the tank and dry out, the pump has a hard time drawing fuel. When the car runs and the lines are filled with gas, it starts easily. Nice theory. I hope the filter is user-friendly!
Partially correct. The only problem w/that theory is your fuel lines DON'T drain back, they're still presurized after turning car off. I still agree that it's a fuel issue but I'm leaning towards injectors sticking open and fuel bleeding into the cylinders. How many miles on the car? last maintenance? Run some STP gas treatment through it and save yourself some $$$ and switch to the middle grade fuel.
