Old 05-18-2007, 04:49 AM   #4
Rate My Car: 137 / 337
Originally Posted by danny123
Is there a certain setup that has made the e36 95 325i turn to its full capabilty, i mean i remeber reading some where that the bmw likes really stiff front strut brace, and a not so stiff sway bar in the back. Or am i just totally lost, and there in only one stiffness?
There's really no "full capability" set up, it's more of "what's comparable to your style of driving" As "Perf" mentioned lowering would be a good start - new struts would also give you a good base to start with. After that it's "SKY & your budget" is the limits. One big thing alot of people forget to consider is "dry weight". Are you going to carry gear in trunk, load it with a ton of stereo gear, passengers? Every 10lbs you add are going to change it's handling characteristics so don't forget to consider the weight when making ANY performance mods. Tires & wheels are another mod people don't consider a major change, which can get you into problems. Bottom line: it's a balance issue - consider EVERYTHING as a total pkge instead of throwing stuff at it to compensate for other changes you've made along the way, your wallet and reliability will thank you in the long run.
