Old 05-15-2007, 05:12 AM   #4
Rate My Car: 106 / 340
The switch panel where the lighter is located is a one piece panel which includes the pocket above it. Feel for a hole at the bottom of the multifunction display (MFD), put your finger in it to pull the display unit forward. The MFD should now simply come out. Once that's removed you'll have room to slide the pocket upwards and out. Then you'll be able to access the bulb.
