Old 05-15-2007, 03:35 AM   #1
lesyoungman
Your Ride: 1995 E36 #20i
Unhappy E36 320 Runs badly When Cold
The car has a serious which started a few weeks ago.
The first symptoms were the car battled to start when it was cold and would run very roughly once it had started, until it got hot, then once hot it ran and started without problems.
I used it like this for a week or so (approx 130km a day) then I filled up with fuel and the problem went away completely for two days. Then the problem came back worse than before to the point that it would not start when it was cold without running it down a hill. When warmed up though it still went ok. It seemed a lot heavier on fuel as well.
When this tank of fuel got down to about half the car started running badly even when hot, it would miss badly (basically die when trying to accelerate) and battle to start, hot or cold.
This got so bad that I could no longer drive it, the motor runs extremely badly now and will most times not rev above 3000 rpm.
It is now un-drivable… Any help appreciated...
