your best bet is to wedge a block between the rotor and the ground so the suspension can't flex then use a tight fitting wrench or 3/4 drive socket set with a tommy bar extension or a strong steel tube then really swing on it, you have to break the seal on the bolts as they are really torqued up tight, with a bit of brute force and perseverence you will do it.
