A lot of e36's have the issue where the coolant sensor says the coolant is low when it actually isn't.. You could change that if you wanted to. As far as the brake circuit error, my car also does that every once in a while. To fix that you need to buy the switch that goes under your steering wheel area. I bought the switch, just haven't put it in yet. The price for it was under $20.
