***as low as $225 shipped*** for a short time only.
The days of the old humming, magnetic core & coil-type ballasts have come to an end.
The digital (electronic) ballast is the latest in ballast innovation. Digital ballasts are more efficient, quieter, cooler, and softer/easier on the bulb all the while allowing for a much smaller and neater package. Digital ballasts do not have any of the usual transformers or capacitors, instead these ballasts have electronic circuitry doing the same job, only much more efficiently using significantly less current.
they have the capability of self diagnostic and reset, including specific protection circuits to detect various lamp- and ballast-fault conditions allowing to safely shutdown or reset the ballast.
when the ballast fires the bulb it sends full power to the cold bulb, Over time, this shortens the bulb life and reduces the output and life span of the bulb, Digital ballasts start by sending a low amount of power to the bulb and steadily increases the power over the next few seconds until the bulb has reached full brightness, This is also known as soft starting, which minimizes the damage to the bulb and increases its life.
After one year of use the usable light coming from bulbs that are run on digital ballasts has decreased significantly less where as the same bulb being used in the coil type ballast would have lost over 10% more usable light over the same period of time.
so what does it all mean to you?? the very best hid kit just got that much better in a much smaller and much neater package that's easy to install.
PROLUMEN
HID LIFETIME WARRANTY
PROLUMEN
HID 2 YEAR WARRANTY
PROLUMEN
HID 1 YEAR WARRANTY
6000k on the left 5000k on the right (courtesy of LuvMy328is, thanks Phil
these kits are in stock ready to ship, no 2 or 3 week delay here, the best kit with the lowest failure rate on the market @ less then 1%.
A ProLumen HID Conversion Kit is another perfect kit for any automobile owner that wants all the advantages of HID's without the factory price.
This is a very high quality kit that has been tried tested and out performs our expectations.
Do not be fooled by the Xenon look a likes they are not even close to what true Xenon offer. Those coated Halogen bulbs will cut down your light output by half or more, using our HID kits your light output will be increased 2-3 times.
What makes this kit such a great buy?
This kit is complete plug and play, remove the stock halogen bulb, plug male connectors from kit into the stock female headlight connector. Very simple install anyone can do it!
Fits into existing headlamp or fog light housings.
All needed hardware and instructions are provided.
Prolumen HID Kits come with a lifetime Warranty.
What does the kit include?
2 Xenon Bulbs
2 HID Ballasts
2 Xenon Ignitors
Detailed online Instructions
guaranteed from one year to life, this is the LAST kit you will ever buy!
you will get the very best in service and support from the
ONLY prolumen authorized dealer.
prolumen kits are available in 4000k, 5000k, 6000k and 8000k, add $25 for 8000k.
install resources(credit goes to jean-claude)
http://www.unitedbimmer.com/forums/l...y-install.html
PROLUMEN
www.bavtoys.com
