Originally Posted by 215BIMMER
yup second one is pad wear sensors, dont worrry they're 10 bucks a piece and a snap to replace (especially while you're replacing your pads. the first one is in the same row as the pad wear light correct?
No, the first one .. the warning sign with an exclamation is in the center, one row higher than that of the second sign.
So, do I have to change the pads and also the sensor? Thanks in advance 215Bimmer.
