Thread: Noob to BMW's
Old 04-22-2007, 04:00 PM   #4
larryglover@gulfviewllc.c
Your Ride: 1995 E36 M50 I6
It all depends on what you want to do. Do you plan on modifying the car at all? ie. supercharger or engine work. If you plan on doing any engine modifications, I would highly recommend staying with an OBD1 engine which is pre-'95. 1996 model year was an OBDII engine which requires flashing the DMU for any engine upgrades. Much more difficult. If do not plan on modifying the car, then I agree with the upper thread, purchase as new as your money can afford.
The only difference between the 325i and 325is is the Sport package - which I highly recommend. Gives you stiffer springs and suspension pieces for spirited driving. Definately get a 5 speed manual - the auto's of that vintage was not very strong. I've gone through two auto trannys and am swapping for a 5 speed.
Other than that, BMW's engine's are very strong and should give you a couple hundred thousand miles of driving as long as you take care of them.
As far as websites, go to Bimmerforums.com which will provide a wealth of information concerning BMW's.
Cheers,
