Have you removed the light unit and checked the connections for power? I'd do that before going looking for relays.
If you have no power at the connectors (just push in type), then you need to look in the fuse box (where the relays are too).
But they are notorious for poor earths and connections. Just try pulling both units out. Clean the terminals and replace them (assuming you have voltage there)
