Can't see enough to justify posting the pic.
Take the top off the big plastic box on the passenger side of the firewall and the relay should be in the front of the box.
I t should come on for 3 seconds at start then turns off if the computer sees a fault. If there is a problem with the relay it won't ever click.
If there is a problem with the fuel pump the relay will click and stay on.
