Welcome. On the power side, set a budget on what you want to work on and build from there. If you start from the basic bolt ons and move up, you might have a better view on what your ultimate goal (power wise) will be. Now, if you have a big wallet, then you can go big off the bat, but won't have that build from the bottom up to compare what worked. Also make sure you get some time on the dyno with a shop that knows what they're doing. Good luck
