Thanks for all the suggestions,
I jacked it up and can wiggle the rear tire about 2-3 mm also a noticable noise when I rotate the wheel, so I am pretty sure the bearing is scrap, I will be tackeling that tonight as the parts have come in, and I bought the proper tools to do the job.
Will let you know tomorrow how I make out.
(if there is no up date I may be stuck under the car) lol
Also will the rear tires need to be aligined after this? If so I may change the other rear bearing as it has 192,000 on it. Although the right one sounds and feels fine.
