Old 04-09-2007, 09:36 AM   #3
akinthecat
Your Ride: 1999 320i
dropped by the shop to check it out. The arm is rock solid and there is no visual indication that the bushings are torn. Could it be the brake rotors or a wheel bearing?? The bearing spins the wheel and there's no shimming but i can't tell from the brake rotors. I might as well do the entire front end and get it replaced.
