Ok, here are the pics:
First is a pic of it closed, a view from the side of the front. I don't know if it's completely obvious but to me it looks like the sunroof sits a bit higher than it should.
Second is another pic of it closed. I guess it's hard to tell that it isn't sitting exactly right but that's the seal that I need.
This one is of the rear of the sunroof. You can see the slice in the seal here, it's right in the middle. I think that's where the two ends meet but they've eroded away a bit, making them about 1/4 inch away from each other.
This one is also a view of the problem seal, except from the inside. That little bit of light coming in in the middle is where the hole is, but like I said before, this isn't the cause (or at least the only cause) of the leak.
