Old 03-27-2007, 01:59 PM   #2
nick_318is
nick_318is's Avatar
Rate My Car: 10 / 337
You can check out a DIY our own member Amanda has done.
Rear Shock replacement
Front Shock Replacement
This should be similar to the process on the e46. You would probably need to find a Spring Compressor, you can usually get one from an autoparts store as long as you leave a deposit.
