Old 03-03-2007, 02:18 AM   #9
elsabor67
elsabor67's Avatar
Rate My Car: 33 / 337
Originally Posted by 215BIMMER
ground i think pin 17 for exactly 3 seconds, and exactly 11 seconds with the key on and engine off. this should reset all the lights,
You're close, it's pin 7 and 18 or seven to ground for 3-6 seconds to get all 5 green and anything past that resets your inspection lights that are there too. I do recommend that the cable you use be fused(a fuse between both ends) and have a second hand there. This link (http://www.noren.com/bmw/e30reset.htm) gives you detailed instructions and has helped me maintain my changes with no problems instead of having to find someone here with the tool to charge me to set the lights again.
How do I spell relief??
AUTOBAHNNNNNNNNN
"GO FASTER !!"
