Old 03-01-2007, 08:32 AM   #6
elsabor67
elsabor67's Avatar
Rate My Car: 35 / 340
Originally Posted by akinthecat
have an oil change asap, using quality oil (i'm using castrol which bmw recommends) and an original filter. Remember to reset the meter again. .
My 2 cents to you is not to use Castrol. I used to be a castrol fan and then switched because it was breaking down so quickly(specially because of the way I drive, WIDE OPEN ). BMW and other mechanics that I know here in Germany recommended for my E30 Mobil-1 10W40 synthetic and it doesn't become drinking water by the time my oil change is due around every 4 mos or 3000 miles. On the light you can reset that yourself if you want. I reset mine every time I do the oil change and when I tune it up.
How do I spell relief??
AUTOBAHNNNNNNNNN
"GO FASTER !!"
