I acvtually started 2 months or so ago. but heres the details:
COMPLETE!! rebuild with:
-CP 8.5:1 forged pistons
-Eagle H-beam Rods
-ARP head studs
-MLS.70" head gasket
-ALL! new gaskets, seals, bearings, chains,rails, tensioners,etc,etc
-New VAC oilpump upgrade
-PWR 57mm ALUMINUM RAD
-Gt35r turbo
-UUC stgeel flywheel with M5 ultra smooth cerametalic clutch
-Full 3 angle valve job
-new valves
-port and poilish head
ARGGHH>>>>>>>> way to much to keep listing. i'll post a spread sheet at the end of alll the mods
VFE supercharger removed and ready to remove from chassis
engine out
intercooler almost mounted:
intercooler mounted and engine bay empty
disassembly continues:
and continues some more:
Head is off and inspecion looks good. all is well.
piston #5 was a little ruff, we'll fix that
block completely stripped and off to the machine shop
old pistons , rods, etc.
crank and olod spark plugs:
The secret to the power- GT35R .82A/R:
VAC MLS .70" head gasket and ARP head studs:
CP pistons. 8.5:1 CR
polished parts;
