Old 02-19-2007, 01:53 PM   #4
QcMarque
QcMarque's Avatar
Your Ride: 1994 740i
you said the fan doesn't work? even if you turn the speed all the way up? I'd say it's the blower motor itself... mine went out not too long ago. 1/2 the time it wouldn't do anything, the other 1/2 it would run, but sounded like s**t... turned out one of the bearings on it went out so it would get bound up, a sharp jarring would break it loose sometimes. Pull the motor and give it a look over. Regardless of anything else the blower motor shoudl work (unless fuses/wiring's bad... but you've already checked that.)
