Originally Posted by 215BIMMER
yea i know how the sensors work i was wondering if they are simple enough that i can just cut somethin to "unshort" it b/c i know when my brakes are bad, id rather not bother wth new sensors every change. and for the fog light no i havent tried a bulb, does the cluster come out easily to change it?
Yes and no... on my car the cluster is held in w/ 3 screws along the top underside (top of cluster), then you just pull the top forward, slide the botton out, turn the steering wheel left while pulling the cluster out that way (after unhooking the wires - be sure to note placement of individual bulbs and single wires.) Reinstalling it is just the opposite. Takes a little patience and practice, but once you do it a couple times it's actually quite simple.
