Originally Posted by Dudesky
Yea, I'd been running the car on the highway the past few days, taking it through its paces, but it hasn't helped. But I just tried disconnecting the battery for about 15min after your post. Just got back from some more driving, now the CEL is only on half the time
if it turns off and turns back on you have a problem, see if it stayed on then it would probably be that you just need to clear it. maybe you didnt connect the wires properly and they keep disconnecting or something else, run the fault code reader again, if its the same reader take a second look at the 02 sensor
