Old 02-12-2007, 10:56 PM   #18
QcMarque
QcMarque's Avatar
Your Ride: 1994 740i
Here's the basic start button wiring (based on my car... which lead to the relay is used on your car may be different, but the basics are the same regardless):
Keep in mind that with this setup, you CAN run the starter while the car is running. If you use the Z8 start button there's a 3rd wire that is run to the hand brake wiring to allow you to run the starter only while the hand brake is set.
