I don't know what metal shield bearings are, but the pulleys are simple to remove and install- just use a hex key (8mm, if I remember correctly) in the center after you pop off the plastic center cover. Then reattaching the belts are easy too- just remember the big one goes on first, then the small one for the AC.
