Old 01-23-2007, 12:12 PM   #33
e30_slideways
e30_slideways's Avatar
Rate My Car: 113 / 340
Your Ride: 1990 325i
Originally Posted by ///M Power
DINAN doesn't make a turbo kit for the e36. They have superchargers, that's it. To turbocharge your vehicle would probably run you close to $6k-$7k. You would put otu about 400 rwhp. Technique Tuning is teh place to go. Get a stage II kit.
if you get a custom turbo manifold, a t3/t4 hybrid turbo, and perhaps a megasquirt ECU, that would run you around $1400.
FMIC, Piping, 48lb injectors, metric blue head bolts, and spark upgrade (unless you have one already) that can be had for around $500.
a t3/t4 is good for up to 22lbs of boost and it will spool around 2200rpms if you do it right.
to save money you can do it yourself. dyno tuning will be expensive, but i am trying to organize a "dyno-day" event. it might be in Fredricksburg, VA however. quite a hike from Fredrick, MD.
