Old 01-04-2007, 07:45 PM   #2
nick_318is
nick_318is's Avatar
Rate My Car: 10 / 340
Do you have brake fluid in the car right now, the clutch works with the fluid from that. If not check into your master cylinder. Please also note that you should probably bleed the clutch and maybe your brakes if you have drained the fluid durring the process and most definitly if there isn't any fluid in there at the moment.
