UPDATE###
I got the stromung exhaust in the mail today. damn this thing is gonna sound awesome!!!
Been busy with bushings (worst job ever!!!!!) stock ones take a lot of patience and willpower to get out and the new ones are almost as hard to put back in. Rear end is basically all done with the SS brake lines, rotors, pads, coilovers, TA bushings, subframe bushings, I'm waiting to do the diff mount until i get the LSD which should be the next thing on the list now.
Just need to bleed the brakes and the rear is set.
Front is IP, pass. strut has been removed, cut off the factory spring perch and put on the GC sleeves. Then put in the Koni Adjustables and mounted them up to the IE race camber plates up top. Will end up cutting the housing in the engine comp so that i can adj for full camber as they don't slide all the way right now. Tomorrow will be the other front strut, rotors, pads, and a full system bleed including the clutch slave which still needs to go in. then the car will be dropped onto the wheels for the first time as a 335i!!!!
Gonna be a noisy trip to the exhaust shop friday or saturday haha.
should have exhaust clips and video as soon as i can. i'm moving this weekend too so you may just have to be patient...
pics of the new parts will come tomorrow i'm thinking
<end tease>
