Originally Posted by bmw111
THANK FOR ADVICE BRO. tHE PROBLEMS I MENTIONED, DO YOU THINK ALL THESE THINGS CAN BE AFFECTED BECAUSE OF AIR FILTER IE BLACK SMOKE , BAD PERFORMANCE AND FUEL CONSUMPTION, I AM CURRENTLEY ONLY GETTING 20MPG WHERE AS BEFORE IT WAS ABOUT 35MPG PLEASE HELP.?
Well first off, caps lock isnt a good thing.
The black smoke could be caused by carbon deposits but in ur case it probably isnt if it wasnt doing it before. Its probably that the mass air flow sensor (MAF) was riped out to and is causing the car to run rich. That would also explain the poor fuel consumption.
heres a pic of my intake to show u were it is:
Its the sqaure little box looking thing that sorta sits atop the hose behind the heat shield.
