Old 09-20-2006, 11:53 PM   #6
habbie
habbie's Avatar
Title: Forum Sponsor
Rate My Car: 1 / 337
Originally Posted by BenDF
Habbie if you are around, I am having some trouble physically installing these into the stock location. Are they supposed to have to be worked in, or are they supposed to slide right into place like stock?
I am scared to put any force into getting them in. Is it at all possible I received the wrong headlights?
they are a tighter fit then the us lights but they do go in fairly easy.
they way i put them in is slide the low beam side in first on an angle then the other side will just slide in, also if your plastic tabs/nut is not turned all the way in it will be very hard to fit the headlights in, mark the tabs before turning them in that way you can unscrew them back to yhe original position.
