Old 09-08-2006, 04:39 PM   #1
3050rpm
3050rpm's Avatar
A Little Tip When Using Jackstands
We're probably all familiar with the admonishment not to put metal to metal when jacking up or supporting the car on stands. The general advice is to use a piece of wood between the hydraulic floor jack disk and the frame or whatever part of the car one is interested in.
If a suitable piece of wood isn't available, I instead use old paperback books, about 1/2-3/4" thick, thereabouts. They work just fine, and there's a ready supply at the used paperback bookstore not far from home, for something like a quarter. I even use them in place of the rubber jacking pads. Somewhere, I can't recall just where, said that those really shouldn't be used to place jacking equipment (for whatever reason, again I can't recall), and instead the pads should be removed but the lifting of the car should be done at those same points. That's what I do, take out the pad, and put a paperback in between.
So if you still have de Tocqueville's "Democracy in America" hanging around somewhere and somehow you figure you won't be finding the time to reread it...
