Lok-Na-Rok!
So I've got a problem that is well known but I couldn't find solution for it. First the instrument needles started falling and then the cluster started again doin it's checks and stuff like if u r putting ur ignition key in 2nd possition. Then it started doing strange things like only the speedometer working or everything without the fuel level gauge working and stuff. I used the search egning but couldn't find how to fix it.
So time for conclusions: The problem is in the cluster itself and everybody knows that. For me it's a waste of too much money to buy a new one and second one is kinda stupid idea as it could stop working any minute.
I've read that it sometimes fixes for a while if u change alternator and stuff after it that makes the voltage steady...
Then in another forum I've found some guy said in the cluster there is something that makes the voltage steady(or something like that) again and it should be replaced.
So if the problem is in the voltage somewhere it seems logical to be this one.
I am going to try this one today with a friend but still it would be nice if u share ur opinion, thoughts and suggestions with me.
Thanks in advance.
