Old 08-08-2006, 06:56 PM   #1
Rooz
Rate My Car: 5 / 340
Your Ride: 2003 M5
DIY DDE in a E46
Step 1: Get all your stuff ready...
Step 2: Take the corner turn signals off by unscrewing them from the top
Then you can just unplug them
Now we're going to start take the headlights apart...
Remove the lower colored match trim by pulling it away from the front of the car...
Then remove the weather strip...
Now remove the plastic cover by unlatching it, fairly easy so far (notice there is 3 latches on the top one on the inner sides and 3 on the bottom...)
Now remove the silver trim panel, BE VERY CAREFULL DO NOT FORCE THIS!
Notice how it is attached....
Then simply pull it out....
You are now done taking the headlight apart :
VIEW MOD LIST & PICS
Originally Posted by Gregg
