Old 08-02-2006, 12:10 AM   #1
SHAHAB323IS
SHAHAB323IS's Avatar
Title: Professional Noob
Your Ride: 1998 323is
Electrically F*cked
I need some MAJOR help
i'm just going to get right into it
earlier today i hardwired a valentine one into my buddie's e46, used a brown ground wire and green and blue power wire from the universal transmitter pre-wire, to attach the v1, worked perfectly
i had already planned to wrap my selector rod with solder for a cheap weighted selector rod as detailed on understeer.com
here:
http://www.understeer.com/cheapwsr.shtml
so i figure what the heck might as well do my valentine one as well, since i already had a project planned
get home
first thing i do is try connecting the v1 to the sunroof switch via black/yellow wire which i believe to be power, and brown ground wire
when i turned on the valetine, the sunroof opened
i'm thinking in my haste i tapped the wires after the switch not before
basically then the sunroof wouldn't close or do anything, it seemed like it was dead, so i get my allen wrench out and close the sunroof manually
then i think oh well i'll take that into work(bmw dealership) tommorow and figure it out probably not a big deal
so then i searched google got a thread from bimmerforums that said use the purple and white hote wire from map/dome light assembly and brown ground wire
so i try that with the wire tap crimp connections
still nothing
after i tried that the map/dome lights don't work
i figure ok done with that do the selector rod
so i do the selector rod
put the car back down
i go to start the car, car starts and immediately dies, basically my life is over is what i'm thinking lol, icv stuck closed? who knows, maybe it's not getting power because of all the electrical problems,
the engine will stay on if i keep the gas pressed in
but as soon as i take my foot of the gas it dies
also during this whole dieing situation, obc read tailight failure, and the driver's side taillight and parking light weren't working, but the turn signal was
then i checked windows they don't work either, and niether do the vanity lights? above the sun visors
so here's where i'm at now:
1)engine turns on, dies immediately, will stay on however if i stay on the gas
(i'm assuming icv isn't getting power with the elctrical mishaps, just assuming)
2)sunroof doesn't move at all
3)windows don't move
4)driver side tail light out
5)driver side parking light won't come on
6)vanity lights out
7)map/dome light out
basically if all else fails i'll have to tow it to my work and hope my boss can hook me up, doubt it though, but i'm definitely going to talk to someone at work tommorow
basically i need help, i rushed something, and continued to rush things, until i thouroughly screwed myself over, and well just looking for any help at all
thanks in advance
