Old 07-20-2006, 08:37 PM   #5
nick_318is
nick_318is's Avatar
Rate My Car: 10 / 340
Check your brake fluid level, the clutch runs off of the same system as the brakes, it might be low on fluid causing the brake fluid light to come on when you press the clutch.
Edit and what exact lights come on if its the brake fluid one then this is probably your problem if the park brake and brake lining lights come on it might be something else.
