Yes yes, I know you can press it, but that's not what I was saying. I know it can revert back. What I was getting at was with the cruise control engaged, and you don't touch it, it will use more gas to go uphill and not take advantage of the downhill slope. You have to play with the pedal to get what you want, which doesn't makes sence. It's just like the cruise control wasn't even there...
Originally Posted by celsdogg
i also notice the CC letting off the throttle too, when going downhill. when i look at the MPG meter the needle is way past 40mpg, then when the CC reapplies the the gas, then it goes back to about 25mpg.
It's doing that to maintain the speed... it could care less of the MPG rating. When going uphill it will apply more gas. In my case, the gauge reads something like 10mpg. If my speed changed while going down hill in a positive direction, then with that momentum built up, cruising uphill will draw less fuel.
Dough
