Originally Posted by Dudesky
You mean this?
This channel notches into the top, and then there is a screw that holds it in place at the bottom. There is some play before you tighten the screw, so you can adjust the track to the movement of the window.
If that track is at the back of the door then yes. But it is not screwed to the door, it is riveted.
Too bad, I was just telling a guy Iknow with an E36 that the power windows in my E34 are very reliable when compared to that of an
E36.
