Old 06-20-2006, 02:48 PM   #2
Rate My Car: 106 / 337
Yes, that's the part number. However, you can't use a standard puller to do the job because the jaws will keep slipping off, and you can't "push" the bushing out from its center. Bimmerworld.com sells the trailing arm bushing tool for $99. Or you can use 2" US NPT pipe caps and 7/16" threaded rod, with some nuts. That is, if you can get that in Europe. Maybe you can try transferring the measurements to metric and find some equivalent hardware.
