Old 05-13-2006, 10:21 AM   #2
mullethunter3
mullethunter3's Avatar
Rate My Car: 162 / 340
Next, I took the sunroof motor cover off. Just pry at the front with a screwdriver and once the front clips are disengaged, it slides forward. (Note: I left the map light assembly until the headliner was almost out, it is a little easier that way since you can release the pressure clips from the back.)
From here, you need to wiggle the sunroof switch out of its wiring harness. I found it stubborn, but maybe it's just old.
From this, I moved onto the "oh shit" handles (as my mom calls them). This is simple, yet be careful, you do not want to break any of the fragile pieces.
First, use a pliers on the screw covers and pull STRAIGHT down, any side to side and the plastic pins will snap. When you uncover the screws, unscrew them but pull the handle straight out since there are more fragile pins.
