Originally Posted by mitch500
how much power do you plan on getting out of this 328 turbo set up . an m3 has 240 hp to the crank thats ruffly 204hp to the rear wheels. so im guessing your running about the same with a turbo and no internal modifications i couldnt see it gaining more than 80-100hp. so im guessing aliitle over 300.
on low boost which will be 7 pounds (or .5 bar) i hope to make around 350 whp. on high boost, prob no more than 14 psi (i only have a 2 bar map sensor), i want to make over 400 whp. how much power i will make will depend on the aggessiveness of the tune. i dont know if you go on bimmerforums at all but there are several guys making over 500whp on stock m52's with low compression head gaskets and arp head studs. on race fuel one of them made 635whp
both these guys are running very similar setups to what i will have. m52's love boost and can hold a lot of it because they come stock with a forged crank and a square block design which helps the head gasket seal very well under boost. m52's hold high boost much better than s50's or 52's.
in a straight line i will be very fast, but i know e30's love to be tossed around through the twisties
by time frame i meant when do you plan to do the swap? an s50/52 e30 would be fucking awesome
